Problems Apache
jplana
Error al iniciar el servicio "httpd".
Cannot start/stop/restart service: Starting httpd: httpd: Syntax error on line 210 of /etc/httpd/conf/httpd.conf: Syntax error on line 14 of /etc/httpd/conf.d/zz010_psa_httpd.conf: Syntax error on line 5 of /usr/local/psa/admin/conf/vhosts_bootstrap.conf.dI8212: Could not open configuration file /var/www/vhosts/ditet.es/conf/13681790150.92325200_httpd.include: No such file or directory
[FAILED]
Solutions ???
- I can not connect to plesk panel 8443
. When I run the command described the following appears:
[root@s15425742 ~]# /usr/local/psa/bin/sw-engine-pleskrun webserver_configuration_checker.php
[2013-05-14 12:12:48][FATAL_ERROR] Plesk version file is not exists /usr/local/psa/version
