Resolved Problems on Roundcube v1.67 after upgrade
hermano.correia
Almalinux 9.4
18.0.63
Good afternoon
After upgrade Plesk I started to have problems with Roundcube.
My versions are:
AlmaLinux 9.4 (Seafoam Ocelot)
Plesk Obsidian Versão 18.0.63
Roundcube Versão 1.67
I don't have access to mailbox giving error to access server.
Can you please help me?
Thanks in advance for any help.
Regards
Hermano Correia
After reading the above post we have disabled Plesk auto-updates on our servers ...
I suggest submitting the case as a ticket to Plesk support so that they can check whether it is a general issue with Roundcube. There is a Roundcube security update in the pipeline, and it would not be good if a Plesk or Roundcube update lead to a broken Roundcube webmail.
fyi...did not experience this issue on either Alma 8.9 or Ubuntu 22.04 after upgrading to 18.0.63 Update 1.
Hi again
Solved following the tip on Webmail Broken After Update to 18.0.61.5
It was a problem on Mod_Security configuration. After whitelisting the rules: 949110, 980170, and 932239, started to work ok.
Thanks for all the help, specialy to @MacGyver !
Regards
