problems running mchk
dragnovich
Basic Pleskian
When I run mchk to regenerate all sites, I get this ...
[root@server ~]# /usr/local/psa/admin/sbin/mchk --without-spam
==> Checking for: mailsrv_conf_init... ok
==> Checking for: mail_handlers_init... ok
==> Checking for: mailsrv_entities_dump... ok
==> Checking for: mail_admin_aliases... ok
==> Checking for: mail_auth_dump... fail
==> Checking for: mailman_lists_dump... ok
==> Checking for: mail_kav8_restore... ok
==> Checking for: mail_responder_restore... ok
==> Checking for: mail_grey_restore... ok
==> Checking for: mail_mailbox_restore... ok
==> Checking for: mail_spf_restore... ok
==> Checking for: mail_dk_restore... ok
==> Checking for: mail_drweb_restore... ok
Errors occured in mail restore procedure
Some utilities have exited with errors:
/usr/lib64/plesk-9.0/mail_auth_dump
the same results is with any params runned, here there are some concerns...
what's mail_auth_dump and what is for??
Why is failing ?
where's a log to trace the problem?
IS REALLY A PROBLEM TO TAKE care or is "optional" or "CRITIC"
any way if I run directly the program: /usr/lib64/plesk-9.0/mail_auth_dump , it runs for a while and nothing is displayed (executed successfully ? )
A note: I have installed CentOS6 /64 bits and Plesk 11.0.9 (how ever it is running that program in /usr/lib64/plesk-9.0 ? is this OK ?}
regards
Most probably that it can be related to missed passwords for some mailboxes. In order to get the list of such email accounts, please run the command:
# echo "SELECT m.mail_name, d.name FROM mail m LEFT JOIN accounts a ON a.id = m.account_id LEFT JOIN domains d ON m.dom_id =d.id WHERE trim(a.password) = ''" |mysql -uadmin -p`cat /etc/psa/.psa.shadow` psa
Then set passwords for found mailboxes and run
#/usr/lib64/plesk-9.0/mail_restore
#/usr/local/psa/admin/sbin/mchk --without-spam
I hope it will help.
Just for my understanding: what's the difference between these two commands? They seem to do just the same. Is there any difference between "mail_restore" and "mchk"?
Looks like no difference:
root@ppu10-4:~# diff /usr/local/psa/admin/sbin/mchk /usr/lib/plesk-9.0/mail_restore
root@ppu10-4:~#
@IgorG
I have the same Problem ...
All entries have no mailbox
For each entry, there is no mailbox, e-mails are forwarded
OS Debian 6.0.6
Plesk 11.0.9 Update #24
Ivan
