• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Issue Problems to del certificate with cli
micneon
Div. Debian, Ubuntu, Rocky Linux
18.0.64.1
Hello,
I would like to delete certificates that are empty via the CLI.
Unfortunately I have the following problem.
You have to enter the certificate name on the manpage.
However, for some domains this is assigned several times and is the same.
If then none of them is in use or the ones with usage 0 are issued first, the one with 0 usage is deleted otherwise it breaks off and I would have to do it manually via web interface which I find unattractive, does anyone have a tip?
Normally you should not have duplicate names or at least ID's or the option delete all unused or ignore used ones.
root@server:~# plesk bin certificate --list -domain sampledomain.de
CSR Priv Cert CA Name Used
Y Y Y Y Lets Encrypt sampledomain.de 3
Y Y Y Y Lets Encrypt sampledomain.de 0
Listing of SSL/TLS certificates repository was successful
plesk bin certificate --remove "Lets Encrypt sampledomain.de" -domain sampledomain.de
One of the certificates you are going to delete is used by domain service.
exit status 1
Greetings Michael
