Resolved Problems with additional IPv4 not working
LorisMod
Ubuntu 20.04 x86_64
Plesk Obsidian 18.0.51.1
Hello,
I have a problem on a Plesk server with adding an additional IP. It shows me no errors after adding it, but it is unreachable and appears to be not configured in the system.
I tried to fix IP as suggested in the form for similar problems, but without fixing and getting error messages:
root@server08u:~# plesk bin ipmanage --repair 158.220.110.81
The IP address 158.220.110.81 was synchronized with the system.
root@server08u:~# plesk db "select status from IP_Addresses where ip_address = '158.220.110.81'";
| status |
| 0 |
But IP does not appear in ifconfig:
root@server08u:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 176.57.150.95 netmask 255.255.255.255 broadcast 0.0.0.0
inet6 fe80::250:56ff:fe43:a61a prefixlen 64 scopeid 0x20<link>
ether 00:50:56:43:a6:1a txqueuelen 1000 (Ethernet)
RX packets 2055605138 bytes 324167394790 (324.1 GB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1457256270 bytes 5099807500228 (5.0 TB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 21808659056 bytes 20977489179929 (20.9 TB)
TX packets 21808659056 bytes 20977489179929 (20.9 TB)
IP does not respond to Ping and is unreachable
If I add a domain with this additional IP the following error appears in the Plesk home page:
nginx: [emerg] bind() to 158.220.110.81:443 failed (99: Cannot assign requested address) nginx: configuration file /etc/nginx/nginx.conf test failed.
With Repair Kit it finds me the following error that it can't fix:
IP address not found on interface(s): 158.220.110.81
Looks like you'll have to add the IP address manually network interface. I am not sure what steps are involved for Ubuntu. But I am sure that if you'll Google around you'll find some information on how to manually add an IP to the network interface in Ubuntu.
Yes, solved by manually adding it to /etc/netplan/01-netcfg.yaml
And applying the change with: netplan apply
Adding it from Plesk is inserted into 10-plesk.yaml, but it is ignored by ubunto, on this VPS
I can't configure my IPv4 address on my Plesk server. When I add the IP it says: This IP address is not configured properly. Repair
I think this happens for the subnet mask. I made many attempts and followed the documents but failed. please help me to configure my IP address.
