    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Problems with cronjob
henkbart
Hello,
Since the upgrade to version 8.3 i got an error on a cronjob :
Cron /opt/kav/5.5/kav4mailservers/bin/parse_avstat.pl -d -sd=/opt/kav/5.5/kav4mailservers/proc_avstat /var/log/kav/5.5/kav4mailservers/avstats.log
This generates the following error :
Logfile '/var/log/kav/5.5/kav4mailservers/avstats.log' does not exist
Doen anyone has this problem and who knows what to do about this problem??
Henk
If file "/var/log/kav/5.5/kav4mailservers/avstats.log" does not exist on server create it. After that you should stop getting this error from cron task.
That solution works for 1 day. After running he renames or deletes that file so the next day i got the same error. Thanks for your suggestion, but that doesn't work quit good.
Looking for a more permanent solution.
Well I have modified the cronjob to be like this :
touch /var/log/kav/5.5/kav4mailservers/avstats.log ; /opt/kav/5.5/kav4mailservers/bin/parse_avstat.pl -d -sd=/opt/kav/5.5/kav4mailservers/proc_avstat /var/log/kav/5.5/kav4mailservers/avstats.log
tested few times. works fine.
Hey, can you tell me where (which file) the cron task is to find?
I don't see any related cron tasks in the dedicated files but I get the same error.
need to know where to look
thanks
Hello steakknife,
The cron generally is set to run under user kluser . You either can edit the cronjob from plesk directly by going under Server -> Scheduled tasks and choose user kluser or you can edit it in ssh directly
crontab -e -u kluser
