Problems with Kaspersky in 10.1.1
Stefan1504
i have still problems with the new kaspesky 8
1. no log files
2. no autoupdate for the virusdatabase
3. no added x-headers in the mails
where are these settings gone after 10.1.1?
Thanks for support
Documentation
Hi IgorG
I'am not very satisfied.
The doc-Link is not up to date - this is the discription for the v.5.5 kav software
in the 10.1.1 version kav8 is the acual version
-rw-r--r-- 1 root root 1207 13. Feb 18:37 appinfo.dat
-rw-r--r-- 1 root root 936 6. Dez 08:56 appinfo.kli
-rwxr-xr-x 1 root root 286 6. Dez 08:56 kav8update*
-rwxr-xr-x 1 root root 1431048 6. Dez 08:56 kavehost*
-rwxr-xr-x 1 root root 88906 6. Dez 08:56 kav-handler*
-rw------- 1 root root 1594 1. Feb 15:30 kav.key
-rwxr-xr-x 1 root root 1766432 6. Dez 08:56 keepup2date8*
-rw-r--r-- 1 root root 214 6. Dez 08:56 kl.pbv
-rw-r--r-- 1 root root 230 6. Dez 08:56 oper.pbv
-rw-r--r-- 1 root root 2535 6. Dez 08:56 settings.xml
please help!
Hi IgorG,
I also have problems with getting Kaspersky to work in Plesk v10.1.1
See also my post here.
My status:
- Server OS: Ubuntu 10.04 x86_64
- Freshly installed Plesk 10.1.1, also installed microupdates #MU1...#MU9.
- Plesk licensing says: Kaspersky key is present and active
- In antivirus settings I could tick the checkbox Kaspersky AntiVirus
- I don't see the module "Kaspersky antivirus"
- I don't see further options for antivirus settings
- In Managing System Services: service Kaspersky Antivirus is not running (red cross), unable to start the service
- Mail is not scanned (no X flag antivirus present)
- I read the documentation but couldn't find a possible solution
- I cannot find the Kaspersky Antivirus module in the distribution
Questions:
- Is it a known bug that will be solved in a next version?
- Should the Kaspersky Antivirus be visible as a module?
- Is there something I can try to get it working? How can I safely uninstall and reinstall the Kaspersky virusscanner?
Thank you
The total lack of response seems like a confirmation to me that this must be a bug.
Can please anyone respond who has the Kaspersky Antivirus to work in combination with Plesk v10.1.1 ? I am curious if this is possible.
