psarestore - mysql problem ( your SQL syntax near 'ENGINE=MyISAM DEFAULT)
P
psifx
Have just done an OS reload, and reinstalled 7.5.4
When performing a psarestore, I see these errors:
Restoring mysql database 'mysql0b51d35d832f6ae18d0e98c4070' ...ERROR 1064 at line 21: You have an error in your SQL syntax near 'ENGINE=MyISAM DEFAULT CHARSET=latin1' at line 19
The dump wa taken from an FC2 platform, which was then reloaded with FC3. I'm *assuming* that the database table structure has changed.....
any ideas?
Thanks,
Paul.
