qmail and plesk help
A
AllanN
hi guys
I hope someone can help. I was using Plesk 8 but the installation was damaged so I decided to try and live without it. All was fine for a while until I installed qmail scanner. I had some problems with it and now I can't seem to get it back to how it was. It seems plesk uses a different type of qmail to the standard.
What I'd like to do is try and get my qmail back to how it was, which means stopping the scanner somehow - but i have no idea where to begin. Any suggestions?
thanks in advance
if anyone has this problem, I managed to get the scanner stopped by uninstalling it using yum -remove qmail-scanner
