• Our team is looking to connect with folks who use email services provided by Plesk, or a premium service. If you'd like to be part of the discovery process and share your experiences, we invite you to complete this short screening survey. If your responses match the persona we are looking for, you'll receive a link to schedule a call at your convenience. We look forward to hearing from you!
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Qmail Problem - qmail-smtpd exited by timeout
W
winnet
I've a problem about my qmail smtp server.
I've looked at the maillog file and I've seen many warning messages such as:
"qmail-queue[19682]: possible qmail-smtpd exited by timeout, reset connection or with "See http://pobox.com/~djb/docs/smtplf.html."
What is the possible cause and solution?
Best regards
Stefano
To eliminate this problem, stop Qmail process and replace qmail-queue, qmail-local and qmail-remote with the qmail-queue.moved, qmail-local.moved and qmail-remote.moved accordingly:
# cd /var/qmail/bin
# cp -p qmail-local.moved qmail-local
# cp -p qmail-remote.moved qmail-remote
# cp -p qmail-queue.moved qmail-queue
If you face any problems replaising these files, you can stop thses processes forsible and then try to replace them:
# killall qmail-remote qmail-queue qmail-local
Make sure that the permissions and ownersips are right:
# ls -la qmail-queue qmail-local qmail-remote
-r-xr-xr-x 1 root qmail 44060 Jun 13 2006 qmail-local
-r-s--x--x 1 qmailq qmail 15784 Jan 26 14:06 qmail-queue
-r-xr-xr-x 1 root qmail 43364 Jun 13 2006 qmail-remote
@Satoriya
Thank you this solved a problem for me. I got the message 451 qq internal bug (#4.3.0) when i tried to send an email from the command line.
I have no idea what it all did but all my mailboxes work now.
From within horde email I got an error 110
All gone, thanks!
is this a bug
Thanks, that fix error message 451 qq internal bug (#4.3.0). Is this a bug or what could have cause this problem? Thank you?
# cd /var/qmail/bin
this is not the solution
this disable spamassassin
Plesk 10.0.1
Jan 26 14:28:53 km31113 qmail-queue-handlers[9481]: possibly qmail-smtpd exited by timeout, reset connection. #011#011#011#011See "http://pobox.com/~djb/docs/smtplf.html." for get more information.
http://kb.odin.com/6763 - not help
same problem after servercrash
hello,
i have the same problem after a server crash. I have do the way with the copy of qmail-local.moved ... and now i have the problem that spamassassin do not work.
I find no way to start spamassassin.
How can i include spamassassin again in qmail with plesk 10?
Thank you for informations.
