Reconfigurator.pl and Virtual network interface (failover Ip)
Mickael Salfati
Regular Pleskian
Hi everybody,
I wanted to use reconfigurator.pl to reconfigure all my existing domains to a new virtual network interface.
Reconfigurator.pl doesn't work with virtual network (Ip failover) and I have "no such interface network" as result.
My configuration: Debian 5/plesk 9.5.4 or Debian 5/plesk 10.1.1 or Debian 6/Plesk 10.2.0 (preview)
My network configuration in /etc/network/interfaces (IP values are just there for example)
Code:
auto eth0
iface eth0 inet static
        address 192.168.10.200
        netmask 255.255.255.0
        network 192.168.10.0
        broadcast 192.168.10.255
        gateway 192.168.10.1
auto eth0:0
iface eth0:0 inet static
        address 192.168.50.200
        netmask 255.255.255.255
So actually my domains work on 192.168.10.200 address and I need to set all domains to 192.168.50.200
So here's my map.txt file:
Code:
eth0:192.168.10.200 255.255.255.0 -> eth0:192.168.50.200 255.255.255.255
I precise that 192.168.50.200 address is not here in Plesk (menu IP address)
So my conclusion, reconfigurator.pl doesn't support failover or virtual network interface.
Is there a solution ? IgorG or other ?
Thank you per advance.
Did you try it http://kb.odin.com/en/943 ?
What exactly errors you have?
Yep Sir :))), I used this kb.
Error is mentionned in my first post but here's exactly the message:
Adding eth0 192.168.50.200 255.255.255.255 > eth0... no such network interface
virtual network interface are not valid for Plesk 9.5.4, 10.1.1 or 10.2.0.
I even tried to delete completely eth0 in /etc/network/interfaces and declare only the virtual network, same result.
Thanks IrgoR for you reply ;)
Did you check output of ifconfig command?
For example, Virtozzo VPSes hasn't eth0 interface. Usually it is venet0:0 or venet0:1
Yep and ifconfig return well eth0, eth0:0
Furthermore, I launch the first time reconfigurator.pl map.txt to create the template file and eth0 is really recognized.
There is no other method or trick to mass update IP domain in plesk ? I have thousand of domains to update :(
According to my experience, this error happen because plesk doesn't recognize eth0:0 interface.
I also tried to use map.txt like that with eth0:0:
Code:
eth0:192.168.10.200 255.255.255.0 -> eth0:0:192.168.50.200 255.255.255.255
or
Code:
eth0 192.168.10.200 255.255.255.0 -> eth0:0 192.168.50.200 255.255.255.255
but I have a parse error :(
Did you check it with real Network interface? It looks like that problem related to this virtual interface...
To be completely clear, I have domains linked to 192.168.10.200 and I need to link now all my domains to 192.168.50.200 (failover IP)
My /etc/network/interfaces
Code:
# The primary network interface
auto eth0
auto eth0:0
Command used: /usr/local/psa/bin/reconfigurator.pl map.txt
I tried two map.txt:
1/with eth0
Code:
eth0 192.168.10.200 255.255.255.0 -> eth0 192.168.50.200 255.255.255.255
Result:
Adding eth0 192.168.50.200 255.255.255.255...eth0: no such network interface.
/opt/psa/admin/bin/ifmng --add eth0 192.168.50.200 255.255.255.255: exited with non-zero code 256
2/with eth0:0
Code:
Result:
eth0 192.168.10.200 255.255.255.0 -> eth0:0 192.168.50.200 255.255.255.255: cannot parse
map.txt: cannot parse, 1 errors found.
Are you sure that new IP 192.168.50.200 doesn't exist in Server -> IP Addresses ?
Yep sure sure. I just updated my previous post to show you my /etc/network/interfaces
Last information, If I go to plesk and launch "Re-read IP address" all IP addresses (even 192.168.50.200) are well configured.
192.168.50.200 shouldn't be listed in IP addresses list before remapping procedure.
Again, it's the case when I launch reconfigurator, 192.168.50.200 is not present, as I said in my first post.
I just wanted to explain to you that after all, If i want to see if IPs are well recognized in Plesk with Re-read Ip function, it's the case ..
Contact support team. They will investigate this issue directly on your server and find a reason.
Got the same problem...
Are there any updates in this case?
Regards
