Issue Recurring Amavis timeout issue — "conversation with 127.0.0.1 timed out" recurring every N months
mcbus94
Basic Pleskian
AlmaLinux 9.8
Plesk Obsidian v18.0.79_build1800260720.04 os_RedHat el9
  • Plesk Obsidian on AlmaLinux 9.8
  • Amavisd 2.13.1-1.el9 (from EPEL)
  • AMD EPYC 7313 (32 cores), 66GB RAM, nginx + PHP 8.4 FPM, MariaDB
Emails fail to send with the following error recurring every N months (pattern not yet identified):
4.4.2 deferred (delivery temporarily suspended: conversation with 127.0.0.1[127.0.0.1] timed out while receiving the initial server greeting)
Last occurrence (today, 24 Jul 2026):
  • 130+ messages queued and blocked, spanning ~12 hours (from ~12:36 until now)
  • All postfix SMTP processes show status "delivery temporarily suspended"
  • Amavisd logs show: (!!)TROUBLE in child_init_hook: BDB can't connect db env. for multiple child processes
Temporary fix (applied successfully):
Following https://support.plesk.com/hc/en-us/articles/15657655076375, restarting services resolves it:
systemctl restart amavisd
systemctl restart postfix
postsuper -r ALL
Messages then process normally.
Problem recurs periodically (frequency TBD, likely monthly or quarterly). Is this a known issue with Amavisd 2.13.1 on AlmaLinux 9.8?
Thank you in advance
Hi, @mcbus94 . Does the issue appear in relatively the same time - is there any pattern you can catch, or does it appear randomly? Please check if OOM has occurred:
Code:
journalctl -k | grep -i -e memory -e oom
Also, you may use the sar utility to check CPU and system load:
Code:
sar -q 2 5
If unavailable, you can install it as follow:
Code:
yum install sysstat
service sysstat start
I can't define a specific time because I only notice the problem when I log into Plesk or in the evening I realize I haven't received a single email.
No memory and no cpu issue, we are using Plesk monitoring.
Thank you for the confirmation. Please navigate to Tools & Settings > Plesk Email Security > Server Settings > Advanced, and confirm if "Concurrent Amavis Processes" is set to the default value of 10. If yes, please try increasing it to 20, for example.
Hi. The issue recurred today. Email are not sent/delivered.
The first email "blocked" has been sent at 13:40:11
<.......@.........>: delivery temporarily suspended: conversation with 127.0.0.1[127.0.0.1] timed out while receiving the initial server greeting
recipient=.........@.............
offset=747
dsn_orig_rcpt=rfc822;..............@..............
status=4.4.2
action=delayed
reason=delivery temporarily suspended: conversation with 127.0.0.1[127.0.0.1] timed out while receiving the initial server greeting
Aug 04 13:15:43 ............. kernel: kcare: allocating memory in module space...
Here below more details that could be useful to find the issue:
$ sudo journalctl -k --since "2026-08-04 13:00:00" | grep -E "kcare|kpatch"
Aug 04 13:15:43 ............. kernel: kcare: allocated 15188191 bytes for patch at ffffac492930d000
Aug 04 13:15:43 ............. kernel: kcare: allocated 15187680 bytes at ffffffffc1f10000
Aug 04 13:15:43 ............. kernel: kpatch: 13 entries unpatched
Aug 04 13:15:43 ............. kernel: kpatch: patching vmlinux, nf_conntrack, xfs, kvm, tls, drm_kms_helper, bnxt_en, dm_mod...
$ sudo journalctl -u amavisd --since "2026-08-04 13:15:00" --until "2026-08-04 13:40:00"
Aug 04 13:22:29 ............. amavis[87163]: NOTICE: reconnecting in response to: err=2006, HY000, DBD::MariaDB::st execute failed: Server has gone away at /usr/share/perl5/vendor_perl/Amavis/Out/SQL/Connection.pm line 175.
Aug 04 13:35:50 ............. amavis[87164]: NOTICE: reconnecting in response to: err=2006, HY000, DBD::MariaDB::st execute failed: Server has gone away
Aug 04 13:35:50 ............. amavis[87165]: NOTICE: reconnecting in response to: err=2006, HY000, DBD::MariaDB::st execute failed: Server has gone away
Aug 04 13:35:50 ............. amavis[87166]: NOTICE: reconnecting in response to: err=2006, HY000, DBD::MariaDB::st execute failed: Server has gone away
Aug 04 13:35:50 ............. amavis[87167]: NOTICE: reconnecting in response to: err=2006, HY000, DBD::MariaDB::st execute failed: Server has gone away
Aug 04 13:35:50 ............. amavis[87168]: NOTICE: reconnecting in response to: err=2006, HY000, DBD::MariaDB::st execute failed: Server has gone away
$ sudo postqueue -p | tail -1
-- 4188 Kbytes in 130 Requests.
I have just set the "Concurrent Amavis Processes" from 10 to 20. Amavis and postfix services have been restarted and email delivery is now OK. But I woudl like to find a solution without reboot amavis and postfix.
