Resolved recurring issue notice automatic updating system packages
Harun
Basic Pleskian
Obsidian
18.0.79
I have received three update emails that begin with:
"Hello, Administrator,
There was an issue with updating system packages and third-party components"
When I check the System Updates page in Plesk, it says: "All packages are up-to-date"
The last successful automatic update was July 9. I've never had to interfere with automatic updates to system packages and third-party components.
July 16, 17:
Reason: Update utility stdout:
Setting up grub-pc (2.06-3~deb11u7) ...
/dev/disk/by-id/scsi-36000c2963705c02ec27ae7a6e8cb4eba does not exist, so cannot grub-install to it!
You must correct your GRUB install devices before proceeding:
July 15:
DEBIAN_FRONTEND=dialog dpkg --configure grub-pc
dpkg --configure -a
dpkg: error processing package grub-pc (--configure):
installed grub-pc package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
grub-pc
Update utility stderr:
2026-07-15 06:25:30 INFO: pum is called with arguments: ['--update', '--json']
2026-07-15 06:25:36 INFO: updating packages: grub-pc-bin grub2-common grub-common grub-pc
N: Ignoring file 'mariadb.list.old_1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E:Sub-process /usr/bin/dpkg returned an error code (1)
2026-07-15 06:25:39 ERROR: installArchives() failed
2026-07-15 06:25:39 ERROR: Exited with returncode 1.
Is this something I should send to the VPS vendor (Ionos, not sure if this is something they will help with) or is it something I can easily address myself?
Additional info: Total hard disk 76GB, 39GB used, 34GB available.
CPU, memory, and disk look normal/low-load around the time of the attempted update.
So I learned to do this:
:~# dpkg --audit
The following packages are only half configured, probably due to problems
configuring them the first time. The configuration should be retried using
dpkg --configure <package> or the configure menu option in dselect:
grub-pc GRand Unified Bootloader, version 2 (PC/BIOS version)
I've not worked with grub-pc before, so I'm unsure how to proceed.
I'm also wondering if I've posted in the correct forum. Please let me know if someone has a better idea where to get help.
I also found this useful: This advice is a few years old though: Resolved - Information on some packages might not be actual: inconsistencies were detected ...
# plesk installer --select-release-current --reinstall-patch --upgrade-installed-components
# /usr/local/psa/bin/sw-engine-pleskrun /usr/local/psa/admin/plib/DailyMaintainance/script.php -f InstallSystemPackageUpdates
The symptom seems to be solved!
The error message is gone. I will know if I don't get the error message again tomorrow!
Hi @Harun
The bootloader isn't managed by Plesk - the only time they interact is when Plesk runs package updates. But even in this case, Plesk just asks the package manager of your OS (Debian/Ubuntu) to perform the update.
It looks like your disk configuration has changed (probably worth asking your VPS provider about it), or there was a bug in bootloader's post-install script. Sometimes, just trying to install/upgrade the package again (which you did, according to your last message) resolves the issue. Happy to hear that the error is gone
I'm not sure what the root problem was. After re-installing packages, I have seen successful updates. Resolved? Fingers crossed!
