Resolved Reducing Postfix "Concurrent Connections" Problem
tetrahall
Regular Pleskian
Centos 7.7
Plesk Obsidian 18.0.74.3
Hello,
I'm trying to reduce the "Concurrent Connections" for sending hotmail/outlook emaails.
The default value is 20. Hotmail requires a value of 3.
So, I;ve added certain lines at *the end* of the following files in postfix.
master.cf
hotmail-throttle unix - - n - 3 smtp
-o syslog_name=postfix-hotmail
-o smtp_destination_rate_delay=1s
-o smtp_destination_concurrency_limit=3
transport
hotmail.com hotmail-throttle:
outlook.com hotmail-throttle:
live.com hotmail-throttle:
msn.com hotmail-throttle:
main.cf
transport_maps = hash:/etc/postfix/transport
When either of the the following commands are run
# postmap /etc/postfix/transport
# postfix reload
This message is displayed"
postmap: warning: /etc/postfix/main.cf, line 735: overriding earlier entry: transport_maps=, hash:/var/spool/postfix/plesk/transport
line 735:
This is the line I added at the bottom of the file "main.cf"
What am I doing wrong, please?
Sounds like your main.cf already has a transport_maps defined. Just delete the line you've made, locate the one that plesk defined already, and add it yours with a comma so it'll look something like this:
transport_maps = hash:/var/spool/postfix/plesk/transport, hash:/etc/postfix/transport
scsa20,
Thank you. The error message has disappeared.
However, to displays all limits, I run this command:
# postconf | grep concurrency_limit
it yields several lines...
default_destination_concurrency_limit = 20
hotmail-throttle_destination_concurrency_limit = $default_destination_concurrency_limit
Shouldn't hotmail-throttle_destination_concurrency_limit = 3?
Also, the following command should display customized (non-default) concurrency settings in main.cf file
#postconf -n | grep concurrency
But it doesn't display anything!
Honestly the best way to test to see if it worked is to simply do a test while tailing the maillog
tail -f /var/log/maillog
And look for the transport. Here's an example of mine when I set it up just now:
Code:
Jan 25 22:34:44 akheera dovecot[]: service=imap, [email protected], ip=[::1]. Disconnected: Logged out rcvd=1162, sent=1885
Jan 25 22:34:44 akheera postfix/smtp[]: DDC: to=<@gmail.com>, relay=gmail-smtp-in.l.google.com[64.233.180.26]:25, delay=1.2, delays=0.23/0.01/0.36/0.58, dsn=2.0.0, status=sent (250 2.0.0 OK  17 -502fc024772si79214681cf.36 - gsmtp)
Jan 25 22:34:46 akheera postfix-hotmail/smtp[]: DDC: to=<@hotmail.com>, relay=hotmail-com.olc.protection.outlook.com[52.101.68.2]:25, delay=3, delays=0.23/0.01/0.65/2.1, dsn=2.6.0, status=sent (250 2.6.0 <acb--7-78c6a900@17646742> [InternalId=, Hostname=DM6PR13MB3772.namprd13.prod.outlook.com] 11446 bytes in 0.306, 36.452 KB/sec Queued mail for delivery -> 250 2.1.5)
As you can see the one sent to gmail used the normal postfix/smtp transport while the one sent to hotmail used the postfix-hotmail/smtp transport.
Sorry, it doesn't work for me.
Every source on google just mentions the steps I outlined in the first post.
This command:
still yields:
Could the answer lie in this command?
Is there a need to attach main.cf, master.cf or transport ?
Another indication that it hasn't worked is that the mail log still states hotmail/outlook "Concurrent Connections" problem.
Can you please confirm what you get when you execute:
Code:
postconf -M | grep hotmail
Also, an example error from the mail log? Thanks in advance.
Sebahat.hadzhi,
Many thanks for your reply. Actually, after my previous message, I contacted support of our hosting company seeking their advice. They suggested, as a first step, to "reboot" the server and flush the mail queue with the command "postqueue -f".
This has worked. No more hotmail/outlook error messages in the mail log.
Thank you for suggesting this:
I will celebrate. The result is:
hotmail-throttle unix - - n - 3 smtp -o syslog_name=postfix-hotmail -o smtp_destination_rate_delay=1s -o smtp_destination_concurrency_limit=3
The question remains: why is it that the following command
still displays nothing ?!
I will leave it at that. The issue has been resolved, thanks to you and to scsa20 for your help
Hello,
master.cf
transport
main.cf
# postfix reload
line 735:
I’m actually running into the same issue and seeing that exact warning about transport_maps being overridden. It looks like Postfix (or Plesk, in my case) already defines a transport_maps entry earlier, and when we add another one at the bottom, Postfix just warns that it’s replacing the previous value. I’m also unsure what the correct way is to extend or modify the existing transport map without breaking what’s already there. If there’s a proper way to merge the custom Hotmail throttling with the existing Plesk-managed transport file, I’d really appreciate some clarification from anyone who’s dealt with this before.
As mention earlier, edit the existing line
Hello,
master.cf
transport
main.cf
# postfix reload
postmap: warning: /etc/postfix/main.cf, line 735: overriding earlier entry: transport_maps=, hash:/var/spool/postfix/plesk/transport this feels similar to health product fulfillment, where you can’t ship everything at once and have to respect carrier limits to ensure deliveries go through smoothly instead of getting blocked.
line 735:
Thanks for clarifying that makes sense now
So if I understand correctly, the key point is that Postfix only allows a single transport_maps definition, and Plesk already manages one by default. Instead of redefining it, the correct approach is to extend the existing transport_maps line and append my custom transport file as an additional map, separated by a comma.
