Issue Scheduled Tasks keep Running
Jay Clearvoyant
Hi all,
So I was doing some tests with scheduled tasks and it appears for some reason my tasks keep on running...
If I visit my tasks manually over browser they just work fine.
It's an php script that does a few things but it doesn't output anything, or is it required for a task to output something?
I started the same task again in hopes that it might do the job but it still didn't.
(Screenshot:
Gyazo - 68189dc45070b0b60c57ce54ab6c327a.png )
The only way to end the tasks is by running the command "service psa restart" (restarting plesk itself).
Which then generates this error:
My version:
Plesk Onyx
Version 17.5.3 Update #27
Any idea guyes?
Thanks!
Actually, you can stop these stuck tasks without restarting psa service. Just go to Plesk database with
# plesk db
Find tasks in longtasks table:
mysql>select * from longtasks;
and delete these tasks.
Yes, I suppose these tasks should be ended with some kind of exit code, isn't it?
