Selinux + RHEL5 problem during installation...
F
fgilain
Hi all,
I'm just installing a new plesk 8.20 server on a RHEL5 platform.
i did sentenfoce=0 as asked in installation guide before running the autoinstaller script, but i get message concerning SElinux very often, here is an extract of the installation log :
Creating initial database
Initial database created
Creating SSL certificate
Generating a 1024 bit RSA private key
writing new private key to '/etc/sso/sso.pem'
problems making Certificate Request
32359:error:0D07A098:asn1 encoding routines:ASN1_mbstring_ncopy:string too short:a_mbstr.c:147:minsize=1
1024 semi-random bytes loaded
Generating DH parameters, 512 bit long safe prime, generator 2
This is going to take a long time
SSL certificate created
Creating SSL CA certificate
writing new private key to '/etc/sso/sso-ca.pem'
SSL CA certificate created
Create SSO config
SSO config created
Installation du package psa-sso-configurator-1.0.0-rhel5.build82070706.15.noarch
/etc/selinux/targeted/contexts/files/file_contexts: Multiple different specifications for /var/qmail/bin(/.*)? (system_u:eek:bject_r:sendmail_exec_t:s0 and system_u:eek:bject_r:bin_t:s0).
Installation du package psa-locale-fr-FR-8.2-build82070706.13.noarch
Trying to establish test connection... connected
done
Any idea of what happens and how to correct this ?
Will this make my server not working in the futur or something like that ?
thanks
Florent
I'm getting this notice as well, but SELinux is disabled:
From /etc/selinux/config
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
# enforcing - SELinux security policy is enforced.
# permissive - SELinux prints warnings instead of enforcing.
# disabled - SELinux is fully disabled.
SELINUX=disabled
# SELINUXTYPE= type of policy in use. Possible values are:
# targeted - Only targeted network daemons are protected.
# strict - Full SELinux protection.
SELINUXTYPE=targeted
~Matt
You can check your SELinux status by running 'sestatus'. If it is set to DISABLED in the config file, that doesn't necessarily mean it is disabled. If you reboot the machine, then it will read the config and not use SELinux. Running 'sestatus' gives you the definitive answer.
I have this same issue on CentOS 5. It started while installing Plesk. And now when I use yum to update something I get these warnings too. SELinux is disabled.
SELinux status: disabled
Yeah, I had that problem too on RHEL5.
What I did was open up :
and removed the line:
/var/qmail/bin(/.*)? system_ubject_r:sendmail_exec_t:s0
Good to go after that.
~Matt
Seeing this too
With CentOS 5, I see this:
/etc/selinux/targeted/contexts/files/file_contexts: Multiple same specifications for /usr/local/sitebuilder/tmp(/.*)?.
every time I do something with RPM. Selinux is disabled:
I think there is a problem with RHEL 5 / CentOS 5
