sesion timeout problems
P
perler
session timeout problems
hi,
since upgrading to 7.5.4 every user gets logged out after a really short time although session timeout is set to 300 mins. what could be the problem here?
PAT
Yes it´s true. Is there a workaround ? Also in CMS Backends the session Time is to short. PHP sessiontime is 1440 but every 20-60 seconds is a Logout.
Please Help
Christian
can someone else reproduce tis problem? schani and I seem to be the only one with that particular problem. any ideas where to look for a wrong settings?
PAT
shani, i solved my problem. i had a misconfigured router which connected my LAN to the net. i have 4 IP adresses and set my gateway interface to
1.2.3.4
255.255.255.0
instead of
1.2.3.4
255.255.255.248
so that outgoing ip packages were sent sometimes with adress 1.2.3.4 and sometimes with 1.2.3.5 which made plesk cancel the session.
check you logs in /usr/local/psa/admin/logs if requests from you have always the same IP
