Resolved Setting logroate_period via CLI does not work
Jens Johansson
Basic Pleskian
Plesk Obsidian 18.0.80
6
I used the Plesk settings cli utility to change the logrotate period of a bunch of servers with this command
Bash:
plesk bin settings -s logrotate_force=true; plesk bin settings -s logrotate_period=30
The Output I got was two times "Parameter was saved." But when I checked the conf files in /etc/logrotate.d/ they were unchanged and still had the old value of 7 days for rotation. Then I waited a couple of days because I thought may be there is a maintenance task the checks the new value and updates the configs accordingly. But the stetting in the confs is still wrong. In the Plesk Interface under Tool & Settings it shows the new value of 30 days and if I apply the settings there, then the configs under /etc/logrotate.d/ get changed immediately. Is this a bug or am I missing something to apply the changes via CLI?
Looks like there is a gap. Could you try these workarounds?
  • Apply in UI (Tools & Settings), or via GraphQL updateServerSettings mutation - that fires the task.
  • Direct util (system logs only, per-domain/plan not touched):/usr/local/psa/admin/sbin/logrot_mng --system-logs --period-type=by_time --period=daily --rot-count=30
  • Per-domain via CLI: plesk bin domain -u <domain> --log-bytime daily --log-max-num-files 30
Thank you, @Daniil Romanov, /usr/local/psa/admin/sbin/logrot_mng --system-logs --period-type=by_time --period=daily --rot-count=30 does the trick for system logs. That is all I was after. The logs of the domains I did separately with a for loop and the per-domain command you mentioned.
