Several Problems after upgrade to 10.0.1
G
Gizmolo
Hi there,
I encounter several problems after the upgrade to 10.0.1.
It starts, that the Healthmonitor only shows 0% on everything.
Changes to domains don't take effect, on every change I have to run wesrvmgmt -v -a
trying to generate a new certificate request ends up in a tempnam error
trying to add a cron job ends up in a tempnam error
OS Linux debian lenny 32 all recent packets.
regards
Marcel
Make sure that you have enough free diskspace. Check system and Plesk logs. Try to recalculate Health Monitor hardware settings with
# /usr/local/psa/bin/sw-engine-pleskrun /usr/local/psa/admin/plib/scripts/setup-health-monitor.php
thanks for the answer.
Even after the usage of the script the health monitor only shows zero values for everything except the total amount of Disc Space and memory but not for the used amount.
For the other problems the solution was to alter the paths in the config, since I used Symlinks and the system seems not to be able to follow them.
regards
Marcel
