Abdullah_Ilgaz
[SOLVED]
Updated - 30.06.2015
Hi there again!
Finally I figure out that what was this problem. I tried many solutions from Odin Plesk, Microsoft forums and other solutions. All are not worked for me. I looked my logs from server and found a date which these troubles were begun. And after that, I went to Control Panel and searched for Applications that were installed after that date. I deleted them and my problem is fixed!
It related with "Using port 21". If you have any programs which are using port 21, you must figure out and try to uninstalling/reinstalling.
[ORIGINAL POST]
01.06.2015
Hi there!
I got trouble with Services about FTP Server. When I try to restart my dedicated server, everything is okay but ftp server is not working. I used Service Tools but whenever I click FTP server, Plesk Service Monitor is not answering me. I can't understand what is going on with it but this is my first time. I'm using Plesk for 5 years. Sometimes i can face with some problems but they were not critical problems. I have to run my server as soon as possible. I need your helps.
Also I want to ask you that where is the problem? and Why did Plesk saying me "defpackagemng failed"? If Service couldn't accept control messages, what should i do? And is there any solution for resolving ControlService problem?
Hi there again!
[ORIGINAL POST]
01.06.2015
Hi there!
