P
picster
Hi everyone,
I have just bought a ssl certificate from GeoTrust using the plesk "Buy Cert" button.
I completed the process at GeoTrust and bought a "GeoTrust - QuickSSL Premium" certificate.
When I login to myplesk.com I can see my certificate, but I don't seem to be able to install it right.
When the purchase process was completed, I received an email from GeoTrust containing my "Your Web Server Certificate"
-----BEGIN CERTIFICATE-----
something
-----END CERTIFICATE-----
To find out how to install the certificate I searched in the Plesk User's Guide and found the topic "Obtaining and Installing SSL Certificates from GeoTrust, Inc. or GoDaddy"
As stated in the help guide I copied the certificate from the email to a file, and from the Domains > domain name > Certificates I clicked the "Browse" button and selected my certificate and clicked "Send File". When I did that I got the followig error:
Error: Unable to find the appropriate private key for the certificate.
I do not know why it says the private key is not appropriate for the certificate, because when I clicked the Buy Cert button, the plesk system created my certificate (www.cyberbit.com), containing a CSR and a Private Key, by it self, just as described in the user's guide. So I assume that the plesk system has sent the CSR to GeoTrust, because I was not asked to fill in any CSR when I bought the certificate from GeoTrust as I usually am when buying the certificate manually.
I have spent several hours looking through this forum, googled and read user manuals to find out what I have done wrong but without success.
I am fairly certain that I have chosen the right certificate for my domain, when I go to Domains > cyberbit.com > Setup it states:
IP Address: 192.168.x.x Exclusive (1)
Certificate: www.somedomain.com (Repository of domain somedomain.com)
which is the certificate I bought and also the only certificate present, except for the plesk default.
If anyone have any ideas why I get this error it would be greately appreciated.
Thanks
something
Thanks
