SSL certificate problems - Help!
F
frej
I am having a problem installing a SSL certificate through a user account on Plesk Reloaded 7.5.x.
I have tried to the Self issued option inside of Plesk and the certificate is successfully issued, but when I go to https://userdomain.com it does not work properly.
I look at the certificate information and see that it is still the Plesk default certificate that is being used, not the one that I issued.
Could someone please explain how to install a certificate from the user interface in Plesk?
Thank you!
You know a website has to have a dedicated ip address when using a SSL cert.?
Re: Re: SSL certificate problems - Help!
Yes I do :)
I have solved the problem!
My own fault...
I forgot to assign the certificate to the IP address at the IP pool.
