    CentOS2Alma discussion
Resolved SSL_accept error > TLS library problem
TomE
Basic Pleskian
Hi all,
I try to send an email with an application via the smtp on the same server, but always get the following error message
Code:
Sep 14 18:06:04 h2849346 postfix/smtpd[18213]: connect from h2849346.stratoserver.net[81.169.209.114]
Sep 14 18:06:04 h2849346 postfix/smtpd[18213]: SSL_accept error from h2849346.stratoserver.net[81.169.209.114]: -1
Sep 14 18:06:04 h2849346 postfix/smtpd[18213]: warning: TLS library problem: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca:../ssl/record/rec_layer_s3.c:1528:SSL alert number 48:
Sep 14 18:06:04 h2849346 postfix/smtpd[18213]: lost connection after CONNECT from h2849346.stratoserver.net[81.169.209.114]
Sep 14 18:06:04 h2849346 postfix/smtpd[18213]: disconnect from h2849346.stratoserver.net[81.169.209.114] commands=0/0
The problem only occurs since I migrated the domain to another server via plesk. The normal e-mail sending via webmail and outlook works fine.
This error message someone says something?
Thanks a lot, Tom
