statistics problem
A
alens
I noticed that /usr/local/psa/var/log/maillog was not rotate about 15days after I made upgrade psa 7.1.6 > 7.5.1.
After searching forum a did check all posible misconfiguration.
- log files are fine, none more than 1GB
- crontab -l
14 5 * * * /usr/local/psa/bin/mysqldump.sh>/dev/null 2>&1
7 4 * * * /usr/local/psa/admin/sbin/statistics >/dev/null 2>&1
i've just run the 'statistics' command, which came up after processing vhost logs with an errormessage: Segmentation fault
Could any one help?
in my email plesk said it was a problem with 7.5.1 and sould be fixed in 7.5.2 which would be released shortly.
