strange error -- need URGENT help
A
admin0
This is a bit strange error that I am facing.
When I add a new IP address to the server, either directly via Remote Desktop or via the Plesk Control panel, Plesk only works on the last IP added. How do I have it such that it binds to all IP address and all http://ip.add.re.ss/ are browseable and not only the last added IP.
Thank you all for your help.
Cheers,
This was an urgent problem.....
He posts it on the 14th of AUGUST and here it is much later on and its still not being answered.
I dont have an answer for you but if you find one please let someone know OK...?
Thanks
Maxx
It was fixed by reinstall before we had a chance to take a look on it and diagnose the problem.
I can only suspect that may be ICF was turned on on that box - it has exactly that effect, only the last IP address works in multi-IP configurations.
