After some issues with emails I tried updating the server. When that process stalled in the interface, I rebooted the server. Now everything is broken
I get the 502 Bad Gateway error when I try to access the Plesk login page.
The repair tool shows Service sw-engine.service Status Stopped
When I try to run
plesk repair all
I get:
/usr/bin/sw-engine: error while loading shared libraries: liblock_manager.so.2: cannot open shared object file: No such file or directory
exit status 127
And
systemctl status sw-engine -l
● sw-engine.service - Startup script for Panel sw-engine
Loaded: loaded (/usr/lib/systemd/system/sw-engine.service; enabled; vendor pr eset: disabled)
Drop-In: /usr/lib/systemd/system/sw-engine.service.d
└─respawn.conf
Active: activating (auto-restart) (Result: exit-code) since Fri 2021-08-13 22 :33:36 CEST; 678ms ago
Process: 8097 ExecStopPost=/usr/bin/find /run/lock/lmlib/ -mindepth 1 -delete (code=exited, status=0/SUCCESS)
Process: 8095 ExecStart=/usr/sbin/sw-engine-fpm --fpm-config /etc/sw-engine/sw -engine-fpm.conf -c /usr/local/psa/admin/conf/php.ini --nodaemonize --pid /run/s w-engine.pid (code=exited, status=127)
Main PID: 8095 (code=exited, status=127)
CGroup: /system.slice/sw-engine.service
systemd[1]: Failed to start Startup script for Panel sw-engine.
systemd[1]: Unit sw-engine.service entered failed state.
yum update
No packages marked for update
Any ideas what I can do to fix this?
p.s. I'm running on Centos
When I try to run
plesk repair all
I get:
exit status 127
And
└─respawn.conf
yum update
