URGENT! Fedora 11 and fresh installation 9.2.3 problem.
kanada
Basic Pleskian
Hello,
i've installed fresh Fedora 11 and trying to setup fresh installation of PLESK on it.
I run parallels_installer_v3.5.0_build090817.16_os_FedoraCore_11_i386 and then:
Select the installation type for Plesk Control Panel
Installation types for the product:
1. (*) Typical
Install typically used components. Recommended for general use.
2. ( ) Full
Install all components.
3. ( ) Custom
Custom components selection. Recommended only for experienced users.
N) Continue installation with selected type; P) Go the previous page; Q) Cancel installing;
L) Overview or change components marked for the installation
To select an installation type or switch product, type the respective number;
Select action [N]:
Retrieving information about the installed packages...
Downloading the file PSA_9.2.3/dist-rpm-FedoraCore-11-i386/build-9.2.3-fc11-i386.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% done.
Downloading the file PSA_9.2.3/update-rpm-FedoraCore-11-i386/update-9.2.3-fc11-i386.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% done.
Downloading the file PSA_9.2.3/thirdparty-rpm-FedoraCore-11-i386/thirdparty-9.2.3-fc11-i386.hdr.gz: 10%..20%..30%..41%..50%..61%..71%..81%..92%..100% done.
Determining the packages that need to be installed.
ERROR: Unable to install the "postgresql-8.3.8-1.fc11.i586" package.
Not all packages were installed.
Please, contact product technical support.
Can somebody update packages of PSA? postgresql-8.3.8-1.fc11.i586 is outdated and i can't do anything with this.
Current version available in Fedora repo is: postgresql-8.3.8-2.fc11
Please fix it ASAP.
Regards,
Alex
I think you don't understand me, i've made below steps:
1. i've installed fresh Fedora 11 and make yum update (all available packages).
2. i've download parallels_installer_v3.5.0_build090817.16_os_FedoraCore_11_i386 && try to install PSK
I don't have any postgresql server installed on clean OS. Plesk installer trying to install postgresql-8.3.8-1.fc11.i586 but on yum repo actually version is postgresql-8.3.8-2.fc11. I get buttom error.
I think this is a bug in PSK installer.
Regards,
Alex
Alex,
As I wrote before, the problem in that you have updated Fedora with yum BEFORE Plesk installation but not AFTER.
