Warning: In safe mode, not everything will work as expected
luisPatrao
I needed to change server where the my site was working (windows server 2003/ plesk 9), but now, in the new server is giving the Warning "Warning: In safe mode, not everything will work as expected" (Windows 2008 R2 SP1 Web Ed./plesk 11).
I checked all the php.ini and safe_mod is off, and with the command "ini_get_all ()" in the index.php file, the value appears:
[safe_mode] => Array ([global_value] => 0 [local_value] => off [access] => 36)
But still, the warning appears, and I'm limited to sending 100 emails.
when I print the phpinfo ():
Loaded Configuration File C: \ Program Files (x86) \ Parallels \ Plesk \ Additional \ PleskPHP5 \ php.ini
Core PHP:
safe_mode Off
safe_mode_gid Off
Environment:
safe_mode Off
safe_mode_gid Off
PHP Variables
_SERVER ['Safe_mode'] Off
_SERVER ["Safe_mode_gid"] Off
_ENV ['Safe_mode'] Off
_ENV ["Safe_mode_gid"] Off
I also tried changing in the php.ini from Off to 0.
also put on .htaccess the line: "php_admin_flag safe_mode off"
but with no result, I do not know what's happening
Can someone help?
(sorry for the English)
Hi, I am having the same problem with php settings changed in php.ini are not loaded when installing Joomla.
Do you have this problem solved?
Best Regards,
Dave
