Question Watchdog problem
Dork
Regular Pleskian
CentOS 7.9
18.0.57 Update #5,
maillog contains the following entry every hour:
Dec 30 13:24:44 h2675909 dovecot: pop3-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, TLS, session=<ovPXO7kNwrF/AAAB>
Dec 30 13:24:44 h2675909 dovecot: pop3-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<k1PYO7kNaMV/AAAB>
Dec 30 13:24:44 h2675909 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, TLS, session=<OJfYO7kNHsR/AAAB>
Dec 30 13:24:44 h2675909 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<d9PYO7kN2pN/AAAB>
I`m very sure that it is watchdog which produced it.
Any idea how to prevent that?
Yes, those are produced by Watchdog. But those are also expected log entries (and not caused by error or anything). If these log entries bother you, you could disable Dovecot monitoring in Watchdog.
Sounds like a soution but not a real solution.
Watchdog should be able to login.
Logging in would produce even more log entries, so I'm not sure that would improve things.
