    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Watchdog problem
M
meto
I've got Plesk 8.0.1 and after installing Watchdog 2 (rel. date 31.11.2006) i get a message:
ERROR: WDExc
Do góryDo góry
Error occurred while building configuration file. For help, refer to technical support.
0: /opt/psa/admin/plib/modules/watchdog/wdlib.php:661
check_monit_config(string '/tmp/monitrc.chk')
1: /opt/psa/admin/plib/modules/watchdog/wdlib.php:616
create_monit_config()
2: /opt/psa/admin/plib/modules/watchdog/wdlib.php:469
monit_service(string 'bind')
3: /opt/psa/admin/plib/modules/watchdog/configure.php:57
require_once(string '/opt/psa/admin/plib/modules/watchdog/configure.php')
4: /opt/psa/admin/plib/modules/watchdog/wdcplib.php:222
wd__require_once(string 'configure.php')
5: /opt/psa/admin/plib/modules/watchdog/preaction.php:24
require_once(string '/opt/psa/admin/plib/modules/watchdog/preaction.php')
6: /opt/psa/admin/htdocs/modules/watchdog/index.php:13
Is there any solution to solve that problem?
