Resolved Problems with Kolab-Installation on Ubuntu 22.04.
dd6usg
Ubuntu 22.04.5 LTS
Plesk Obsidian v18.0.69_build1800250411.09 os_Ubuntu 22.04
Good Morning and nice Eastern,
I have a problem with the Kolab Plesk Premium Email, the install process fails with
tderr: E: Failed to fetch https://mirror.apheleia-it.ch/repos...amd64/libkolabxml1v5_1.3.1-0~kolab3_amd64.deb: File has unexpected size (678620 != 678618). Mirror sync in progress? [IP: 212.103.80.162 443]
Hashes of expected file:
- SHA256:3000d6057da0bb439eb702541dbb1750f03ab070764a596a8b13496c9767ceb5
- SHA1:3eeab60c297bdd3ea32c4597be41971fab0ca87b [weak]
- MD5Sum:332c014bbce0f58a333060bd16affc92 [weak]
- Filesize:678618 [weak]
E: Unable to fetch some packages; try '-o APT::Get::Fix-Missing=true' to continue with missing packages
Task failed: id=309, pid=250822, type=ext-kolab-task_install, error=pm_Exception_ResultException: Execution guam-start-enable has failed with exit code 5, stdout: , stderr: Unit guam.service does not exist, proceeding anyway.
Failed to enable unit: Unit file guam.service does not exist.
Failed to start guam.service: Unit guam.service not found.
file: /opt/psa/admin/plib/pm/ApiCli.php
line: 343
code: 5
trace: #0 /opt/psa/admin/plib/pm/ApiCli.php(333): pm_ApiCli::filterResult(string 'guam-start-enable', integer '5', string '', string 'Unit guam.service does not exist, proceeding anyway.
Failed to enable unit: Unit file guam.service d...', integer '5')
#1 /opt/psa/admin/plib/pm/ApiCli.php(132): pm_ApiCli::execWithPipes(string 'guam-start-enable', string ''/opt/psa/admin/bin/modules/kolab/guam-start-enable' ', integer '5', array, string '')
#2 /opt/psa/admin/plib/modules/kolab/library/Installer/Debian.php(228): pm_ApiCli::callSbin(string 'guam-start-enable')
#3 /opt/psa/admin/plib/modules/kolab/library/Task/Install.php(11): Modules_Kolab_Installer_Debian->install(object of type Modules_Kolab_Task_Install)
#4 /opt/psa/admin/plib/Task/Control/Sdk.php(49): Modules_Kolab_Task_Install->run()
#5 /opt/psa/admin/plib/Db/Table/Broker/LongTasks.php(178): Plesk\Task\Control\Sdk->run()
#6 /opt/psa/admin/plib/Db/Table/Broker/LongTasks.php(113): Db_Table_Broker_LongTasks->_syncStart(object of type Db_Table_Row_LongTask)
#7 /opt/psa/admin/plib/Task/Async/Executor.php(54): Db_Table_Broker_LongTasks->runTaskWithinExecutor(object of type Db_Table_Row_LongTask)
#8 /opt/psa/admin/plib/scripts/task-async-executor.php(6): Task_Async_Executor->execute()
For me it looks like Kolab has a problem ?
best regards, Gerald.
Thank you, in the meanwhile the installation works but now it gives 502 bad gateway nginx for the webmail page....
