100% of CPU load with an import SQL from sw-engine-fpm
Henri
Basic Pleskian
Hello, together,
I have a problem in Plesk 12 on Centos 6. 6.
Follower: I have imports in via phpMyAdmin a file SQL, this process lasted rather long (the file SQL is approx. 10 mb) I tried whole over again the import, however, though ran through it lasted felt 5 minutes, then I have looked via SSH sometimes with top how high the load is to examine whether there is a problem with the MySQL version.
Indeed, MySQL is not the problem sw separate engine fpm, sw engine fpm does the CPU on just 100%, no miracle the import so long lasts.
Enclosed the extract from top like he to the import of the file SQL looked:
Code:
  PID USER  PR  NI  VIRT  RES  SHR S %CPU %MEM  TIME+  COMMAND
25026 psaadm  20  0  500m  85m  16m R 97.4  1.5  2:21.69 sw-engine-fpm
 1789 mysql  20  0 1186m 315m 7980 S  1.3  5.4  4:12.25 mysqld
 2127 root  20  0 1346m  15m 2424 S  0.3  0.3  7:55.30 fail2ban-server
In the LOG under:/var/log/sw_cp_server/sw-engine. log is to be seen nothing remarkable.
Does somebody have an idea or similar problems?
The file SQL is from Magento (sample Data for Magento)
Greetings Henri
Hello Albi,
No it happens even when I simply update the phpMyAdmin page with F5,
it looks something like this:
Code:
 PID USER PR NI VIRT RES SHR S% CPU% MEM TIME COMMAND +
30123 psaadm 20 0 447m 33m 16m S 20,6 0,6 0: 02.02 sw-Motor-fpm
1789 mysql 20 0 1186m 301m 7984 S 10.6 5.2 5: 31,19 mysqld
30126 psaadm 20 0 446m 33m 16m S 8,6 0,6 0: 01,79 sw-Motor-fpm
30125 psaadm 20 0 445m 32m 16m S 6,0 0,6 0: 02.01 sw-Motor-fpm
30127 psaadm 20 0 446m 33m 17m S 4,7 0,6 0: 01,48 sw-Motor-fpm
30121 psaadm 20 0 443m 30m 17m S 4,0 0,5 0: 01.97 sw-Motor-fpm
1428 sw-cp-se 20 0 46044 4168 1792 S 0,7 0,1 0: 04,77 sw-cp-serverd [/ code]
Grüße Henri[/COLOR][/FONT]
[QUOTE="abdi, post: 782748, member: 58278"]Does the CPU increase to 100% when ONLY importing that SQL file?[/QUOTE]
Normally if the table is extremely large with extremely many rows this sometimes can also slow the MySQL server responding...On some acassions I also noticed the no of open files limit causing PHP fpm slowing down
Simply use mysql via SSH. Import via phpMyAdmin very long and brutal.
Code:
mysql -uuser -ppassword databasename < /path/to/dump.sql
Hi Abdi,
thanks for your answer.
It is a Magento database in the database but is not yet in it, it's basically a very fresh Magento installation.
Do you have a limit set in the open files?
Greetings Henri
