11.0.9 Plesk Installation problem
DloadD
Debian Squeeze 6 , 64X
Hi, I have a problem installing Plesk 11.0.9 :
Code:
There are 82 packages required for the product to function properly, which
were not found in your system.
There are 0 packages that need to be upgraded
in order to install the product.
N) Install packages;
S) Show a list of packages; L) Return to primary components list;
Q) Cancel installing;
Select an action [N]:
Installing packages
Synchronizing the Debian APT package index files...
ERROR: An error occurred during performing of installation PREP actions (see log                  for details). Installation was rolled back.
Warning! Not all packages were installed.
Please check if your system services are operable.
Please resolve this issue and try installing the packages again.
If you cannot resolve the issue on your own, contact product technical support f                 or assistance.
What to do?
Cordialy ,
Have you setup the correct hostname for your server? Please check your hostname entry in /etc/hosts file
