503 due to maintenance downtime or capacity problems
PaulZ
I just installed plesk 12.5.30 to a new server and we moved our system to this server.
On my server i run cronjobs which requires a lot of insertation into the database. When ever this cronjob is running the website freeze or i am getting a
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Untill the cronjob is done. On my other server this cronjob runned without a problem so i am sure it must be a setting on my server probable caused by plesk.
Hoping anyone here can help me with this!
In my error log i see the following
/var/log/plesk-php56-fpm/error.log
server reached max_children setting (5), consider raising it
then again if i look here:
/etc/php-fpm.d/www.conf.saved_by_psa
pm.max_children = 50
anyone?
Hi Paul
If you go to...
Plesk > Subscriptions > domain.tld > PHP Settings > Scroll to down to Additional directives
There you can add custom php-fpm settings for the domain, like so...
Code:
[php-fpm-pool-settings]
pm = dynamic
pm.start_servers = 3
pm.min_spare_servers = 3
pm.max_spare_servers = 8
pm.max_children = 35
That is just an example.
I hope that helps
Regards
Lloyd
By the way, if you are running Plesk PHP versions, you can find the default php-fpm.conf files here...
/opt/plesk/php/<version>/etc/php-fpm.d/domain.tld.conf
The path /etc/php-fpm.d/ is for the OS Provided version.
But you should add any customization as I described above.
Anyway I hope that helps.
Regards
Lloyd
Hi Paul,
please be aware that the file you have edited may be overwritten..
Code:
; ATTENTION!
; DO NOT MODIFY THIS FILE BECAUSE IT WAS GENERATED AUTOMATICALLY,
; SO ALL YOUR CHANGES WILL BE LOST THE NEXT TIME THE FILE IS GENERATED.
; If you need to customize this file, use either custom PHP settings tab in
; Panel or override settings in /var/www/vhosts/system/domain.tld/conf/php.ini.
; To override pool configuration options, specify them in [php-fpm-pool-settings]
; section of /var/www/vhosts/system/domain.tld/conf/php.ini file.
So I would suggest adding them in Plesk too.
Regards
Lloyd
Txs for pointing this out, normally i am developer so this is not my area of expertise.
Maybe a stupid question:
pm = dynamic
Does this need a closing tag?
Something like
pm = dynamic
[/php-fpm-pool-settings]
or just
pm = dynamic
No problem, happy to help.
No you don't need a closing tag, just like...
Code:
pm = dynamic
Is fine.
Kind regards
Lloyd
