After upgrade 9.5 to 10.0.1, httpd doesn't work, please help!!!
Kenan
Basic Pleskian
I upgraded plesk 9.5 to 10.0.1 and httpd doesn't work (FAILED). When i log in to plesk by admin, i get that error:
"Error: New files of configuration for Apache web server were not built due to errors in configuration templates. The detailed error message was e-mailed to you, so please check the e-mail, fix the errors, and click here to retry generating configuration."
And all websites are down now. When i try to run the httpd on ssh, i get an error that:
"Starting httpd: [Sat Mar 05 23:59:09 2011] [warn] module ssl_module is already loaded, skipping [FAILED]"
Please help me, how can i fix it? This is urgent...
Thanks, regards.
This likely means that you had some domain-level Apache configuration files that were migrated from your previous server. Check in your /var/www/vhosts/example.com/conf/ folder for each domain. If you see any vhost.conf files, rename them, then click the link in Plesk to try again.
See this discussion for more information:
http://forum.parallels.com/printthread.php?t=105566
