After upgrade to 8.6.0 PLESK will not start problem whit mysql
F
francoisc
I started an upgrade to 8.6.0 and now PLESK will not start.
I have the following logs. Can anyone provide a solution?
START psa-8.6.0-rhel3.build86080722.01 upgrading AT Fri May 15 17:49:24 EST 2009
Trying to register service xinetd... using /sbin/chkconfig
done
Setting the default locale
The default locale is set to en-US (ENGLISH, UNITED STATES)
===> Installing rbash
Checking that /bin/rbash registered as login shell...
/bin/rbash
/bin/rbash is already registered as login shell
Trying to restart service mysqld... mysqld (pid 8164) is running...
done
===> Installing psa database
Trying to start MySQL server... mysqld (pid 8164) is running...
Trying to define valid mysql credentials... Trying to establish test connection... ERROR 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Trying to establish test connection... Error reading '/root/.my.cnf' file.
Fatal error in defaults handling. Program aborted
ERROR while trying to establish test connection
Aborting...
STOP psa-8.6.0-rhel3.build86080722.01 upgrading AT Fri May 15 17:49:25 EST 2009
i tryed to creat the .my.cnf still unable to connect but the mysql.sock work find all site our ok mysql is runnning
I have rebuilt it with:
rm -f /var/lib/rpm/__db.00*
rpm -vv --rebuilddb
and forced the update with
rpm -Uvh * --force
still doing the samething
And when i check for the install plesk db version
mysql -uadmin -p`cat /etc/psa/.psa.shadow` psa -e"select * from misc where param = 'version';"
i have this
| param | val |
| version | 0840 |
How can i upgarde the DB version of plesk ??? OR any other sugjection ???
If you need more logs no problem, tell me
