• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
ASP FORM SCRIPT help please
Thanks, all of these were there except for this:
that would stop it from working!
does it work now?
Do they need to use the mailenable api instead of CDONTS or CDOSYS?
nope all should work!
i use CDOSYS as it gives better error information than CDONTS. not looked into mailenables api i only presumed it has one.
i am happy using CDOSYS i posted some code on page 1 of this thread.
if you cant get it to work send me a private message with your current mailenable log and i will see if i can see the problem !
ooh yes just a thought
under mail enable admin
localhost -> system -> services
make sure they are all running!...... i expect they are, otherwise you would have other problems .
AndiC_UK
Originally posted by AndiC_UK
Thanks for the replies!!
does it work now?
I have emailed customer to check
How can I look at the logs? Where are they located? Is there a way to view them real time?
They are all running=)
Thanks in advance for the help!!!
AndiC_UK
mailenable admin
got to connectors -> SMTP -> logs
there are three different types all with usefull info.
i use the activity most off the time
no its not real time you have to close a log, hit the refresh button and reopen/open new log. :mad:
regards
AndiC_UK
mailenable admin
regards
AndiC_UK
still not working:mad:
send me a activity log via PM at time of test.
and i will try ti help
AndiC_UK
AndiC_UK
There isn't anything in the mailenable smtp activity log. Does SMTP need to be enabled for IIS for this to work?
After further investigation. When submitting the form it gives a "page cannot be displayed error". I wasnt seeing this error before because I use Mozilla, but on IE 6 that error is displayed so something isn't set up right. The script works fine at a different host.
You can also use jmail from http://www.dimac.net/
There is a free version that works fine also with al lot of domains. This one also works with MailEnable. There are some examples on this site that explain.
After the installation of Plesk 7 the default smtp server (MS IIS) is altered. The server runs on port 8025. Try using this port in your scripts but check your relay settings in iis manager!
Yes, I think MS SMTP needs to be installed for CDOSYS to work at all IIRC.
