H
harveyf
Just moved from a shared hosting environment to a VPS with Plesk 8.3.0, its a very steep learning curve so I have decided to try and find my way around with a couple of domains I dont use but have lurched into problems already!
The domain I want to use on the VPS is hosted with another provider.
In the plesk control panel I have set up the web using the default template which creates the following records
PTR Record
NS record
A Record
MS Record
CNAME for web site
CNAME for FTP
mail A Record
ns A Record
webmail A Record
All this looks fine and I can preview the site from within Plex, the site is the standard holding page but typing in the domain name or using FTP is not possible.
Where I am having problems is with actually getting the domain to point to the server and resolve correctly and I have to admit to being somewhat out of my depth here.
I understand that in the domain name admin panel at the domain hosting company I have to redirect to the VPS. I have used this feature before to point the domains to my existing shared hosting provider, they are not the same. It was simply a case of setting the primary and secondary name servers to the hosting provider ns1.xxx.net, ns2.xxx.net etc
The first question is should I have Plesk set up as the master DNS or Secondary DNS and then following from that what information should I need to enter into the domain admin system
Would the primary name server be still remain with the domain company and the secondary point to the nameserver in plesk or should I be directing both primary and secondary nameservers to the ns.mydomainname.com that plesk has set up
I am very confused as you can probably tell so any help would be greatly appreciated.
PTR Record
NS record
A Record
MS Record
CNAME for web site
CNAME for FTP
mail A Record
ns A Record
webmail A Record
