• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
Big problem with plesk 10.4.4 : php setting features not saving per domain
D
dubres
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
PLESK, 10.4.4, CENTOS 6, 64x
Linux 2.6.38
PROBLEM DESCRIPTION AND STEPS TO REPRODUCE
When i (or my customer) want to change php setting value like safe_mode or max_time_execution it doesn't work and save wrong values like explained in http://forum.parallels.com/showthread.php?t=209634
ACTUAL RESULT
PHP settings not saving correctly per domain
EXPECTED RESULT
PHP setting changes correctly for each configured domain
ANY ADDITIONAL INFORMATION
the php setting features is "the" new features in plesk 10.4.4 and that's why i changed from 9.5 to give ability to my customer to change the php.ini of their domain in a simple way because i don't allow them to acces via ssh, but until now no fixes was available, there are many topics that talk about it :
http://forum.parallels.com/showthread.php?t=209766
http://forum.parallels.com/showthread.php?t=209664
and no solution or updates was released !!! and i can't access every time via ssh to change php setting, i have more than 100 hosted domain and plesk seems to be as Parallels says : "Easy to use with features like a new, more intuitive end-user interface. "
so please Igor, try to release a micro updates to fix this problem definitively !!!
thank you !!!
