Bind problems on Plesk panel 11
PaddingtonC
Basic Pleskian
Good day,
I am having a problem with installing bind9 on Ubuntu 12.04 LTS. I have installed a Plesk 11 server but DNS service is not running.
root@cp11:~# apt-get install bind
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package bind is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
bind9 dnsutils dnsutils:i386 bind9:i386 manpages
E: Package 'bind' has no installation candidate
root@cp11:~#
root@cp11:~# /etc/init.d/bind9 start
* Starting domain name service... bind9 [fail]
root@cp11:~# /etc/init.d/bind9 restart
* Stopping domain name service... bind9 [ OK ]
When I try to check the log file:
root@cp11:~# tail -f /var/log/messages
tail: cannot open `/var/log/messages' for reading: No such file or directory
I checked in /etc and there is a bind directory
root@cp11:/etc/bind# ls
bind.keys db.127 db.empty db.root named.conf.default-zones named.conf.options rndc.key
db.0 db.255 db.local named.conf named.conf.local rndc.conf zones.rfc1918
When I try to uninstall bind9 it also removes the Plesk control panel.
So I updated and the upgraded the packages and I see bind error:
root@cp11:~# apt-get upgrade
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.2.0-23-generic
Processing triggers for resolvconf ...
Processing triggers for python-support ...
Errors were encountered while processing:
bind9
E: Sub-process /usr/bin/dpkg returned an error code (1)
I found a work around.
This is caused by apparmor conflicting with bind in a Plesk set up, so remove apparmor more:
root@cp11:~# /etc/init.d/apparmor teardown
* Unloading AppArmor profiles [ OK ]
then start bind
