Changing Plan for a domain, does not update website hosting settings (asp, aspnet)
Status
Not open for further replies.
krt463
OS Microsoft Windows Server 2008 R2 Service Pack 1
Panel version 11.5.30 Update #47
Hello, We have a few hosting plans setup with different "allowances" for each.
In Basic Hosting: The website permissions allow basic html and PHP
In Windows Advanced: The website settings allow for html, php, asp and asp.net
When we change a Basic Hosting plan to Windows Advanced using "Change Plan", it will reassign the subscription/domain to use the new plan, but it will not add-on the extra features in Hosting Settings.
Has anyone else seen this?
Resolved:
This happens when the "Hosting Settings Management" option is ticked (check box is ticked). When this option is set, it will not change the hosting settings of any existing subscriptions that are being moved to use the plan.
Draw-back: Now the customers cannot change their PHP version, or ASP.NET versions on their own.
from Parallels Support:
Plesk Panel >> Service Plans >> Service Plan Name >> Permissions >> un-tick "Hosting settings management"
Once you done with the above changes, the service plan changes will take effect without any issue."
Status
