chilisoft (SUN ASP 4.x) installation
The command in the event manager
/usr/local/psa/bin/addvhostperm.sh ><new_domain_name> <new_system_user>
Does not create the vhosts file when new accounts are added????
It appears to be truncated?
Do you have the correct string syntax?
Dont worry I figuired it out, replace the event manager command on the first post to
/usr/local/psa/bin/addvhostperm.sh <new_domain_name> <new_system_user>
And All is GOOD!
:D
And All is GOOD!
:D
Thanks a lot! :)
same problem as bran
I'm on Fedora Core 2 and Plesk 7.5.3. When I install ChiliASP 4.0.2 I don't get permissions or 500 errors but my helloworld.asp won't display.
In /etc/httpd/logs/error_log I get:
[notice] child pid 19126 exit signal Segmentation fault (11)
Each time I try to view an .asp page. Having viewed the rest of this thread and Bran's posts on the Sun forum (where it doesn't look like he got any joy) I don't think ChilliASP will run on Fedora Core 2 with Plesk 7.5.3 or at least not yet....
Does any one know how to help here?
Re: same problem as bran
Hello,
I had the same error with fedora core2. With centos everything works fine. You must only chmod the httpdocs to 751 to activate asp for a vhost.
kind regards,
bram
