Control Panel - Selecting Features and Personalizing
G
globodata
01. First of all, my costumer accessing their control panel using the address https//ip_number:8443/ . There´s a friendly link to access beyond this, like the webmail, for instance, where you have a link withou the IP number ?
02. I´d also like to block some features of the control panel as I´m able to do in cPanel, where I can choose wich feature will be show in the control panel. In Plesk I just could see the hability to give permission to the user access or not, backup and scheduller. Is there a way to block features ?
03. About personalizing the conrol panel, I´ve just could change the Plesk logo in the top frame, but I´d like , for instance, to take off the Plesk name in the login windows, for instance. Is there a way to take off this from login window and create ne skin for the control panel ?
