Issue DKIM problem with alias domain
Erwan
Regular Pleskian
AlmaLinux 9.6
18.0.71
Hi all,
We have a website configured with domain A and two alias domains (B & C) with email and DNS.
DKIM is enabled at the email level.
When we send an email via a dedicated script (PHPMailer - PHP 8.1), with contact@B as the sender, everything works except that the DKIM signature is invalid.
Tested with Mail-tester.com & appmaildev.com.
After various tests/changes at the PHPmailer & Postfix level, we still have the problem.
If I do this simple test:
$mail = new PHPMailer();
$mail->setFrom("[email protected]", "[email protected]");
$mail->addAddress("[email protected]", "[email protected]");
$mail->isHTML(true);
$mail->Subject = "This is a test";
$mail->Body = "Test";
$mail->CharSet = 'UTF-8';
$mail->send();
AppMaildev said there is a problem:
Public-Key: v=DKIM1; p=MIGfMA......;;
DKIM-Result: fail (bad signature)
This seems to indicate that the signature is indeed added by Postfix/Plesk, but it is incorrect (wrong private/public key pair).
In Plesk DNS, DKIM keys are the same for the 3 domains.
The private key in /etc/domainkeys/domainA/default & /etc/domainkeys/domainB/default are the same...
How to fix the problem?
Just to be sure, did you also check if the DKIM DNS records for the alias domain has the correct value or that there is no duplicate record for the DKIM key?
If the DKIM key in the DNS record is valid you might want to try run the repair utility for the domain plesk repair mail example.com -y to see if that solves the issue.
Sorry, the DKIM DNS are defined for the 3 domains (main and 2 aliases) but are differents:
Main domain: default._domainkey.domainA.com. TXT v=DKIM1; p=MIIBIj........IDAQAB;
Alias1: default._domainkey.domainB.com. TXT v=DKIM1; p=MIGfMA........IDAQAB;;
Alias2: default._domainkey.domainC.com. TXT v=DKIM1; p=MIGfMA........IDAQAB;;
Both aliases have the same keys.
I've made this command about ten times :(
I just redid it. No change. Note that the command is only valid for the main domain.
Maybe try removing the alias and re-adding it?
Are you able to successfully send an email from webmail if you add the alias a sender profile in there?
I am unable to replicate the issue on my server, which makes it a hard to come up any more suggestions.
I can't. This is prod website behind it.
For webmail, I can only log in with the main account [email protected]. There is a certificate error to access webmail.domainB.com. But no problem with the email account under Outlook for example.
@Erwan , could you please execute the following command and confirm what the owner and group of the file are:
Code:
ls -l /etc/domainkeys/domain.com/default
I find it crazy that the certificate is not properly managed via the alias and there is nothing that can be done.
Unfortunately, I am unable the replicate the same behavior on any of my servers. Which makes it difficult diagnose what's causing the issue your having. For me, when using an alias domain as the sender in a PHPMailer script always correctly validates DKIM.
I am sure there is a solution, but based on the information you provided it's hard to say what's causing the issue. You'll probably have to troubleshoot this some more. Here's what I would do to further troubleshoot this:
  • Send an email from both the main domain and the alias using the PHPMailer script and carefully compare the mail headers of each email to see if there are any clues/abnormalities.
  • Try the same scenario with different, newly added, domains to see if the results are the same.
  • Try different sending methods like SMTP and php's native mail() function to see if you're getting different results.
  • Set up a test server and replicate the same scenario to see if you're getting the different results.
  • Temporarily switch to Qmail and back to Postfix (or visa versa) to see if that makes a difference.
