Resolved Docker deactivated in components, still running
Oliver Marugg
Basic Pleskian
Hi
Just a question:
Currently I do not (yet) need docker on my plesk. I deactivated Docker in add/remove components and it seems to be not active (red).
But there are still running docker processes. What about disabling with servicectl? I just do not want probably unstablize the running system, I've got no test server.
Any experiences from plesk users with disabling this docker service?
Hi Oliver Marugg,
pls. consider to REMOVE docker - related packages with apt-get/aptitude/dpkg on Ubuntu/Debian based systems, if you do not need it. Search for the corresponding package names with for example :
Code:
dpkg -l | grep docker
Example output:
Code:
ii  docker-ce                             17.03.1~ce-0~ubuntu-xenial                           amd64        Docker: the open-source application container engine
rc  docker-engine                         17.04.0~ce-0~ubuntu-xenial                           amd64        Docker: the open-source application container engine
Example "how to REMOVE the packages":
Code:
aptitude purge docker-ce docker-engine
