Error 500 Problem with Plesk Panel Login
iKovah
[Solved] Error 500 Problem with Plesk Panel Login
Hello folks,
i've tried a lot of commands to fix my problem but it's not solved jet.
I'm getting the Error 500 while trying to log into the plesk panel. Everything else is working fine, all websites are online, mailservice is online etc.
Strage: i'm getting this error after install TeamSpeak Server on my VPS...?!
The following errors are displayed in the /var/log/sw-cp-server/error_log
2012-10-07 21:29:25: (mod_fastcgi.c.1068) the fastcgi-backend /usr/bin/sw-engine-cgi -c /opt/psa/admin/conf/php.ini -d auto_$
2012-10-07 21:29:25: (mod_fastcgi.c.1072) child exited with status 1 /usr/bin/sw-engine-cgi -c /opt/psa/admin/conf/php.ini -$
2012-10-07 21:29:25: (mod_fastcgi.c.1075) If you're trying to run your app as a FastCGI backend, make sure you're using the $
If this is PHP on Gentoo, add 'fastcgi' to the USE flags.
2012-10-07 21:29:25: (mod_fastcgi.c.1171) [ERROR]: spawning fcgi failed.
Must be suid root
I allready red the thread about this problem after an update (500 Error after automatic micro-update - Plesk 10.4) but i have two problems:
1) I'm using Plesk Panel Version 11.0.9
2) I'm using Ubuntu 10.04
And now... do i have to reinstall the packages? Or anything other?
Please help me fast.... =(
Could you please show output of command:
ls -la /usr/lib/sw-cp-server/sw-suexec
it should be like
-rws--x--- 1 root sw-cp-server 354661 2011-06-22 11:40 /usr/lib/sw-cp-server/sw-suexec
if it's not, then set permissions by
chmod 4710 /usr/lib/sw-cp-server/sw-suexec
Solved!
This is really incredible.... really!
A simple permission change solved the whole problem?!
Thanks for the help!!!
And i hope this could help any other admins searching for solutions! =)
