Issue Fail2Ban installation problem
Simpleweb
Hello to all,
i'm on plesk onlyx and CentOS 6.10 (Final) . When i try to install fail2ban i have this error
Code:
Installation started in background
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirrors.prometeus.net
* epel: pkg.adfinis-sygroup.ch
* extras: mirrors.prometeus.net
* updates: mirrors.prometeus.net
+ plesk-fail2ban-configurator
+ fail2ban
Installazione dei pacchetti
Removing stale lock file /var/lock/parallels-panel-bootstrapper-running.lock
Running rpm_check_debug
I have to follow this tutorial (Resolved - plesk component installer hangs at Running rpm_check_debug) to unlock the situation but the fail2ban is not installed.
I had fail2ban installed but for some reason the service was no longer started so i decided to unistall all but now i'm in this situation.
How can i do?
Thanks
