Resolved Failed to check system configuration - Yum utility finished with errors. Installation may fail
The issue is likely caused by that Python version. Instead, create a symbolic link to the 2.x version that should also be on your system.
1) Ensure that Python 2.7.5 is installed
Code:
# rpm -q python-2.7.5
python-2.7.5-90.el7.x86_64
2) Proceed only if python 2.7 is found in step (1). Change the symlink from python3 to python 2.7.
Code:
# mv /bin/python{,.orig}; ln -s /bin/python2.7 /usr/bin/python
3) Retry yum as you did before.
