FTP and PHP permissions problem
P-and-P
Hi Community
I got this Problem after install a New Plesk Server.
Current: CentOS 6.5, Plesk 11.5.30, PHP 5.3.3 (Default install), PHP as FastCGI (I Tried also with Plesk 12.x).
What I did: in IP Tables i set al Ports for Plesk; I set in /etc/proftpd.conf the Ports "PassivePorts 65000 65200"
Problem: Each file ore folder created by an php Application i cant see ore override by ftp.
Example: I Upload a new installation of Joomla 2.5 (CMS) by ftp with a User created by plesk. Then I start the Installation by using the Webbrowser. In this process Joomla change some files and create also an configuration.php. All done by php Scripts. Now I check the configuration.php on the FTP -> Cant see it. -> I check by SSH and the file exists. If I Check the Permissions it seams, that all file have same permissions, owner and group.
Some has an idea whats the problem?
-> Configuration.php can not see by ftp ore be overwritten
-> htaccess.txt I see by ftp and i can manage
->> Permissions seams to be the same "?"!"
