Having big problems with plesk auto updater
Juan ManuelT
Ok, a bit of background:
Machine was a plesk 11, ubuntu 10.04 installed from the official iso back when plesk 11 was released, kept up to date.
-Few months ago, I noticed plesk was auto-updating itself a lot, although I had it set up so it warned me and didnt install updates itself. I switched the configuration a bit, hoping it would overwrite whatever was wrong. Left it so it would only warn me and using the "late adopter release", and it seemed to stop.
-Las thursday I got a mail from the plesk panel, suddently plesk not only updated, but upgraded itself to plesk 11.5. Thankfully the damage was minimal, but this could have been a huge problem, specially if someday it decides to upgrade php or something like that. So 2 questions
1) Anyone else with the same issue, or any recommendation about how to stop it?
2) What ports could I block so Plesk is physically unable of updating for the time being?
Thanks in advance.
EDIT: whopps, wrong forum, can this be deleted or moved to the plesk 11 forum? Sorry.
Hello,
Have you disable "Automatically download and install updates" in your Server settings ? Please try to disable it so that sapless will update on your server automatically
